Hofmann1
Oct 07, 2014Aspirant
Netgear ReadyNAS Duo v1 salvage operation
Short version: I have a 3TB disk with all my data, that only my old ReadyNAS can access. Right now I can't access it through the ReadyNAS either, cause unknown. I want to keep the data, and avoid a fo...
mdgm-ntgr
Oct 08, 2014NETGEAR Employee Retired
If the rear shows the v1 layout then it is a v1.
That sticker at the bottom would indicate it is a v1 hardware revision 2.
