Hofmann1
Oct 07, 2014Aspirant
Netgear ReadyNAS Duo v1 salvage operation
Short version: I have a 3TB disk with all my data, that only my old ReadyNAS can access. Right now I can't access it through the ReadyNAS either, cause unknown. I want to keep the data, and avoid a fo...
Oct 10, 2014Guru - Experienced User
I was thinking that also. I know that the duo would only see a small fraction of the 3 TB drive, but I don't know exactly what part it sees/formats. If the disk is used, there certainly would be residue in places the duo didn't know about.
if you had an old PC that also didn't have bios support for 3 TB drives, then perhaps linux reader would work on that machine???
