Hofmann1
Oct 07, 2014Aspirant
Netgear ReadyNAS Duo v1 salvage operation
Short version: I have a 3TB disk with all my data, that only my old ReadyNAS can access. Right now I can't access it through the ReadyNAS either, cause unknown. I want to keep the data, and avoid a fo...
vandermerwe
Oct 18, 2014Master
I dont have any more ideas, unless you can find another duo v1 and try the disk in their.
Perhaps you can mount the disk in a minus pc or if you install a Linux OS on your PC?
