muxyd
Jan 02, 2016Aspirant
Netgear readynas rnd2000 recovery
Hi Guys, I have a Netgear readynas rnd2000 bought some time in 2010. I have 2 2TB hdd configured as RAID0. So the storage was 4 TB. Now it seems the device stopped working. it is not getting d...
Jan 02, 2016Guru - Experienced User
You cannot migrate the disks to any current NAS, but you could look for a used duo v1 or used nv+ v1.
If the NAS isn't powering at all (no lights, etc) it might be the power brick. If you google, you can find replacements fairly easily.
RAID-0 is particularly vulnerable to disk failures (though that doesn't seem to be your issue). So if you do manage to get the data back, you should definitely put a backup plan in place.
muxyd
Thanks for the reply.
When the device is powered on, the fan runs continuosly. The power button light blinks and thats it. Nothing else.
So it is not the issue with the power brick. (Btw i tried swaping it too without any luck).
