sioboop
Aug 28, 2018Aspirant
Netgear RN 314
One: can't find ReadyNAS 314 on the Model list here...
Two: The reason I am here is because I bought this over three years ago and I was able to connect to it maybe ONCE. I beleive there are fi...
JohnCM_S
Aug 28, 2018NETGEAR Employee Retired
Hi sioboop,
Welcome to the Community!
You can do a factory default on the NAS. This will erase all the data and reset the settings to default. You can check this link on how to access the boot menu and select the factory default option.
sioboop
Thanks! That looks like exactly what I need.
Siobhan
