Matthewj
Sep 25, 2016Aspirant
Netgear RND4000 NAS setup
I am having trouble setting up my Ready NAS server since I relocated offices. I have RAIDar installed and its picking up the device however when I advancd to the next step of pushing the browse butto...
mdgm-ntgr
Sep 26, 2016NETGEAR Employee Retired
Is the I.P. of the NAS in the same range as your PC?
If not, you will need to either do an OS Re-install or
temporarily set the I.P. address of the NIC in your PC to be in the same range as your NAS, login to your NAS, change the settings for the NAS from static back to DHCP and then change the NIC settings for your PC back to what they were before.
