patprs
Aug 16, 2016Tutor
nettoyage des instantanées
Bonjour; mon NAS contient des instantanées (couleur jaune) alors que j'ai supprimé tous les 'snapshot' présents; mais l'espace ne semble pas libéré .... Comment détruire réllement les instantanées p...
BrianL2
Aug 16, 2016NETGEAR Employee Retired
Hi patprs,
Have you considered defragmentation or balancing your system? This could free up the space that you're expecting after removing all your snapshots.
Kind regards,
BrianL
NETGEAR Community Team
- patprsAug 18, 2016Tutor
Hi Brianl,
Partially but defragmentation is not the way, "cleaning" is ongoing and I'll launch balancing after
I'll keep you inform
- JennCAug 18, 2016NETGEAR Employee Retired
- patprsAug 22, 2016Tutor
Thanks for this helpful aticle you're right to have bettezr understanding of possiblities
- JohnRoAug 22, 2016NETGEAR Employee Retired
Hi patprs,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
Hi John; yes no pb but action is ongoing
balancing has been starting more than two days ago, progession is ...0% may be it's very very long
scrubbing has finished in around tow days, with no results as defragmenting on my problem (snapshots seem still occupy the space)
