0deuce0
Oct 12, 2011Aspirant
Network traffic after TM is complete.
After my time machine backup is complete, there is still some network traffic and my "Time Machine Backups" is still mounted. If I eject that mount, the traffic stops. I looked through the forms...
0deuce0
Interesting... It has to do with finder... I thought I put the backup volume in the ignore list but will look into it...
porta-deuce:LaunchDaemons username$ fuser -u /Volumes/Time\ Machine\ Backups
/Volumes/Time Machine Backups: 316(username) 2938(username) 2939(username) 2997(username)
porta-deuce:LaunchDaemons username$ ps -ef | grep 316
501 316 295 0 Sun08PM ?? 0:49.91 /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
porta-deuce:LaunchDaemons username$ ps -ef | grep 2938
501 2938 295 0 9:25AM ?? 0:04.46 /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker -s mdworker -c MDSImporterWorker -m com.apple.mdworker.pool.2
501 3007 2305 0 10:28AM ttys000 0:00.00 grep 2938
porta-deuce:LaunchDaemons username$ ps -ef | grep 2997
501 2997 295 0 10:27AM ?? 0:00.27 /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker32 -s mdworker-lsb -c MDSImporterWorker -m com.apple.mdworker.i386.0
501 3009 2305 0 10:29AM ttys000 0:00.00 grep 2997
Confirmed... I have the "Time Machine Backups" in my Prevent Spotlight from searching these locations list."
When you add it though it does pop up with a "Time Machine Backups is a Time Machine backup disk. Spotlight will continue to search Time Machine backups but will not search other items on the disk."
hmmmmmm
Anyone have any other ideas?
Running 4.2.19
OSX 10.7.1
hmmmmmm
Running 4.2.19
OSX 10.7.1
