jkeroes's avatar
jkeroes
New drive is marked "Dead"
In my ReadyNAS NV+ v2 running Raidiator 4.1.14, there were 4x Seagate ST31500341AS 1397 GB drives. One failed. On the hardware compatibility list, I see that there's a 3GB Seagate and the NAS should ...
  • StephenB's avatar
    Sep 13, 2015
    jkeroes wrote:
    In my ReadyNAS NV+ v2 running Raidiator 4.1.14...
    Your mistake is right here.  You have an NV+ v1 (v2 platforms all run 5.x.x firmware).  The v1 is limited to 2 TB drives, because there is no GPT support.
    You are not alone in being confused on this, lots of people before you have made the same error.  The labels are confusing - read through this info if you want more information: http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
    jkeroes wrote:
    ...I ordered a ST3000DM001-1ER166, and added it.
    I no longer recommend desktop drives in any NAS (whether they are on the HCL or not).  Both Seagate and Western Digital have NAS-purposed products (Seagate VN drives, WDC Red and Red Pro).  They are much better choices.
    Lots of NAS owners (not just ReadyNAS) have had issues specifically with the Seagate DM drives.
ProSupport for Business
