Scrossland
Nov 01, 2017Aspirant
New Drive issue
Disk 1 was showing up as degraded, so I assumed the HDD was bad and replaced it. When I replaced it, it is now saying that Disk 2 is inactive and should be removed and Disk 1 volume is degraded. I j...
Nov 02, 2017Guru - Experienced User
A disk drive is never reported as degraded, only the volume can be degraded. That message means that the volume has lost it's redundancy. You then need to sort out why before you replace a disk.
What firmware are you running?
If you are using XRAID, then power down your system, and restore the original disk 1 in slot 1. Remove the drive in slot 2 (leaving it empty).
Then power up the system and confirm that your data is present. Then you can hot-insert your newly purchased disk into slot 2. You likely will need to format it on the volumes tab before the NAS will add it to the array.
Scrossland
Dec 30, 2017Aspirant
Ended up doing a factory reset because I could not figure out why it was degraded... Thanks
