bgg1
Dec 28, 2016Aspirant
New HDDs failing in Pro 2
Hello, I've been running a ReadyNAS Pro 2 with two 2TB WD red drives. I primarily use it as a backup and media server. I recently bought two 3TB drives (also red) to expand. Along the way I did somet...
- Jan 05, 2017
bgg1 wrote:
With one old drive in, everything else (except for the few corrupted folders) seems to be working well - I can access all other files (at least the ones I tried), and can stream movies on Plex to my phone from both the drive and from an attached USB drive.
I'm not sure what the underlying issue is.
Options I see are
(a) try again on the new hard drive install/expansion. That might work, but some file corruption likely remains.
(b) format one of the 3 TB drives in a PC, and copy the data off the NAS to it. Then remove both 2 TB drives, and do a factory install with the remaining 3 TB drive. Reconfigure the NAS, install your apps, and restore the data from the copy. Then move the 3 TB drive from the PC to the NAS. This will take longer, but will ensure that everything is clean when you are done. You'd also preserve both of the 2 TB drives.
bgg1
Jan 01, 2017Aspirant
When you say data do you mean on the 3TB drives or another copy elsewhere?
If the 3TB drives then I'll have to check again by connecting them internally. If you mean a copy elsewhere then no, although I could probably rebuild if I had the time.
