bgg1
Dec 28, 2016Aspirant
New HDDs failing in Pro 2
Hello, I've been running a ReadyNAS Pro 2 with two 2TB WD red drives. I primarily use it as a backup and media server. I recently bought two 3TB drives (also red) to expand. Along the way I did somet...
- Jan 05, 2017
bgg1 wrote:
With one old drive in, everything else (except for the few corrupted folders) seems to be working well - I can access all other files (at least the ones I tried), and can stream movies on Plex to my phone from both the drive and from an attached USB drive.
I'm not sure what the underlying issue is.
Options I see are
(a) try again on the new hard drive install/expansion. That might work, but some file corruption likely remains.
(b) format one of the 3 TB drives in a PC, and copy the data off the NAS to it. Then remove both 2 TB drives, and do a factory install with the remaining 3 TB drive. Reconfigure the NAS, install your apps, and restore the data from the copy. Then move the 3 TB drive from the PC to the NAS. This will take longer, but will ensure that everything is clean when you are done. You'd also preserve both of the 2 TB drives.
bgg1
Jan 03, 2017Aspirant
So I put in one of the original drives on its own and it seems to be working. Now what's the next step if I want to try expanding again to the larger drives?
Jan 03, 2017Guru - Experienced User
I'd recommend making sure you have an up-to-date backup first. That might be more important than usual here, because you've already run into issues.
If you have a backup, you can simply install both of the new drives and try a factory default. Then reconfigure the NAS and restore the data from the backup.
You can also try hot-inserting the first new drive (leaving the NAS running) and see if you have better luck with the resync this time.
