bgg1
Dec 28, 2016Aspirant
New HDDs failing in Pro 2
Hello, I've been running a ReadyNAS Pro 2 with two 2TB WD red drives. I primarily use it as a backup and media server. I recently bought two 3TB drives (also red) to expand. Along the way I did somet...
- Jan 05, 2017
bgg1 wrote:
With one old drive in, everything else (except for the few corrupted folders) seems to be working well - I can access all other files (at least the ones I tried), and can stream movies on Plex to my phone from both the drive and from an attached USB drive.
I'm not sure what the underlying issue is.
Options I see are
(a) try again on the new hard drive install/expansion. That might work, but some file corruption likely remains.
(b) format one of the 3 TB drives in a PC, and copy the data off the NAS to it. Then remove both 2 TB drives, and do a factory install with the remaining 3 TB drive. Reconfigure the NAS, install your apps, and restore the data from the copy. Then move the 3 TB drive from the PC to the NAS. This will take longer, but will ensure that everything is clean when you are done. You'd also preserve both of the 2 TB drives.
bgg1
Jan 16, 2017Aspirant
Just an interim update - backed up everything to the internal 3TB drive, and upgraded to OS6 with the other drive. Everything copied back. Next up adding the second drive back to the NAS next time I'm home. Thanks for all the help until now. I'll finalize and accept solution as soon as I finish and confirm that all working perfectly.
- FramerVJan 21, 2017NETGEAR Employee Retired
Hi bgg1,
Thank you for the update. I will keep the thread open for you.
- bgg1Jan 22, 2017Aspirant
Just a final note thanking the community and especially StephenB for the patience and solution (even if we couldn't figure out the cause of the problem). System is back up and running fine with the new 3TB drives, and running OS6. I'll likely be starting a couple of new threads for some advice on other aspects of disk maintenance, backup, etc.
Thanks again
- JennCJan 23, 2017NETGEAR Employee Retired
Hello bgg1,
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
