barefoot1
Jul 27, 2013Aspirant
Newb install/expand on a RN102
Greetings ReadyNASers, I got sick of the dreadful performance of my too-cheap-to-believe no-brand NAS, so got a RN102 to fit the same pair of 2TB Seagate Barracuda discs in. Being paranoid about...
mnordin
Aug 07, 2013Aspirant
I submitted a ticket to Netgear tech support got fast reply.
The origin for my issue was that the smaller disks were not on the HCL. I could get the initial setup up and going, but that is most likely the cause for the vertical storage expansion to fail. With supported disks it should have worked out.
I will return my 2TB's to use in the old Duo, and only go forward with the newer (and supported) 4TB Seagate disks in the RN104.
