trevski
Jan 26, 2012Aspirant
NFS enable on ReadyNas Duo v2?
Hi Is NFS enabled on this model? I am attempting to setup a NFS share on my PH A-110. Does this model support it? Not clear in searches? Thanks
mdgm-ntgr
Jan 26, 2012NETGEAR Employee Retired
The Duo v2 and NV+ v2 don't currently support NFS.
However if you are comfortable with the command line you can enable it: http://ubuntuforums.org/showthread.php?p=11599502
You can enable SSH access by installing this add-on: http://www.readynas.com/download/addons/arm/5.3/EnableRootSSH_1.0-arm.bin
Username is 'root' not 'admin' and password should be set by default to your admin password.
On Mac or Linux use the Terminal. In Mac OS X this is found under Applications > Utilities Terminal
On Windows, download the free PuTTy app and use that to connect.
You can simply change the 'root' password though:
NetGear wrote:
With the EnableRootSSH add-on, you can now remote login to the ReadyNAS RAIDiator shell as a root user. Initial password for root will be the same as the current FrontView admin password. Please keep in mind that NETGEAR may deny support if you’ve enabled root access.
ssh root@ip.address.of.nas
MDGM-NAS:~# passwd
Enter new UNIX password:
Retype new UNIX password:
passwd: password updated successfully
