sg86
Sep 23, 2015Aspirant
NFS mount libuuid user
Hi, i've had this issue a few times, on some machines and not others. After mounting one of my shares using "mount -t nfs" the mount location's permissions seem totally messed up. 0 drwxrw...
- Feb 25, 2016
Something doesn't feel right. I used to be able to connect via NFS no problem at all, from multiple boxes including a linux sat box and android box.
I'm going to backup everything and factory reset, i fear its the only solution, and hopefully this fixes things.
Feb 25, 2016Guru - Experienced User
sg86 wrote:
You said UID must match, that is surely ludicrous?
It might be ludicrous, but NFS just doesn't have many UID mapping options.
See for instance http://www.troubleshooters.com/linux/nfs.htm The relevant section is right above "Mounting an NFS share on a client".
sg86
Feb 25, 2016Aspirant
