Jophus
Feb 01, 2021Luminary
ng-csd Onedrive broken
Hello Team. ReadyNAS 316 running 6.10.4. Onedrive worked fine and then it didn't. I have linux dash installed and can see repeated small spikes of CPU from 0 to 33% and Ondrive refuses to sync. W...
- Mar 16, 2021
I had to remove the existing links/sessions and then re-create them. I have had no problems since then.
Syloc
Feb 07, 2021Aspirant
Hi,
I've the same problem as you, and for me the only way to overtake the trouble has been to disconnect and reconnect the onedrive plugins.
However, the plugin is still having a lot of trouble and when I installed and configured it with ssh I got any problem gone.
I suggest the Netgear's Dev Team to give a more efficient support about it because as for the Google Drive plugin, a problem will always appears suddenly with no reason whatever your disks or your connection.
