ikonuk
Aug 15, 2023Guide
Nighthawk software reports vulnerabilities with ReadyNAS Firmware 6.10.9
My NETGEAR router has been reporting vulnerabilities with the latest firmware (6.10.9) as it can be seen from the following screen capture. Is NETGEAR going to do anything about it? I. Konuk ...
Aug 15, 2023Guru - Experienced User
I agree with schumaku that the lack of detail in the report makes it not actionable.
What services do you have enabled on the NAS?
Do you have any ports forwarded to the NAS in the router?
Is your NAS set up to allow anonymous access to shares?
Another possibility is that the NAS is allowing SMB 1 connections - which you could disable is smbplus is installed.
ikonuk
Aug 15, 2023Guide
Thank you @schumaku and @StephenB.
I did have SMB and iTunes enabled for some reason. I disabled it. I will post the outcome.
No ports are forwarded.
