stopgapit
Aug 24, 2016Aspirant
No access to admin webinterface during raid rebuild
The readynas 104 web interface has died during data rebuild, i can ping the device but no web GUI. The LCD display status: Booting ( for last 2 hours ) It's running firmware 6.4.2 Ac...
BrianL2
Aug 25, 2016NETGEAR Employee Retired
Hi stopgapit,
I suppose that you can't also access your files. If you want to access or backup your files,boot the unit in volume read-only mode. Also, can you tell us the most recent changes you made on your system that might have caused this?
Kind regards,
BrianL
NETGEAR Community Team
- mdgm-ntgrAug 25, 2016NETGEAR Employee Retired
Getting stuck on booting could also possibly indicate there is another failed disk. Did you check the SMART stats of the disks before adding/replacing a disk?
- May 25, 2022Retired_Member
