Johncrisps
Apr 09, 2019Aspirant
no access to nas using radar or via website
Reset the NAs to factory settings. Cab access the frontview on browser but it does not show shares or lists on the left hand side. I can change the password OK. Have tried using Radar (latest version...
Apr 09, 2019Guru - Experienced User
If you are running Windows 10, then you need the SMB 1 client enabled in the PC. You can enable that in "turn windows features on or off".
Johncrisps wrote:
If this NAS is too ancient is it better to bin it and get a more up to date model?
My own Duo is still in service as a backup NAS. So it is possible to use it. However, a new NAS would run more modern protocols (SMB 3 for instance), would have more features, more capacity, and would be lot faster.
Johncrisps wrote:
Have tried using Radar (latest version downloaded) but it's not able to find the router on the network.
RAIDar isn't designed to find your router, so I am confused. Do you mean it's not able to find the NAS? It's possible that you have internet security software that is blocking it.
- JohncrispsApr 10, 2019Aspirant
Thanks for the reply
I'm using windows 7 pro
My mistake re router, should be NAS as you deducted.
I use Avast and I've tried switching that off as well, no luck.
Have also looked at teatures as well and tried it on a win10 pc just in case it was the win 7 pc that was the problem
Your point regarding buying a new one with enhanced features is looking better by the minute
It just seems a shame to ditch a reasonably useful bit of kit.
Many thanks
- StephenBApr 10, 2019Guru - Experienced User
Have you tried entering \\nas-ip-address in the File Explorer address bar?
Maybe also try posting a screenshot of what you do see in Frontview.
What size disks are you installing?
Hi Stephen B, thanks for that
I've tried all mentioned:-
Entering NAS ip address gets me into main page which is BLANK on shares and no list on the L.Hand side. I can get to password change that's all.
Drives is 2 x 500gb that were OK previously and have been checked fully.
As noted before I'ver dried Radar app and checked that additionasl s/ware is present
So...??????
John
