Johncrisps
Apr 09, 2019Aspirant
no access to nas using radar or via website
Reset the NAs to factory settings. Cab access the frontview on browser but it does not show shares or lists on the left hand side. I can change the password OK. Have tried using Radar (latest version...
Johncrisps
Apr 10, 2019Aspirant
Thanks for the reply
I'm using windows 7 pro
My mistake re router, should be NAS as you deducted.
I use Avast and I've tried switching that off as well, no luck.
Have also looked at teatures as well and tried it on a win10 pc just in case it was the win 7 pc that was the problem
Your point regarding buying a new one with enhanced features is looking better by the minute
It just seems a shame to ditch a reasonably useful bit of kit.
Many thanks
Apr 10, 2019Guru - Experienced User
Have you tried entering \\nas-ip-address in the File Explorer address bar?
Maybe also try posting a screenshot of what you do see in Frontview.
What size disks are you installing?
- JohncrispsApr 10, 2019Aspirant
Hi Stephen B, thanks for that
I've tried all mentioned:-
Entering NAS ip address gets me into main page which is BLANK on shares and no list on the L.Hand side. I can get to password change that's all.
Drives is 2 x 500gb that were OK previously and have been checked fully.
As noted before I'ver dried Radar app and checked that additionasl s/ware is present
So...??????
John
- StephenBApr 10, 2019Guru - Experienced User
Entering \\Nas-IP-address in the file explorer address bar won't launch your browser. Note the direction of the slash.
What browser are you using? Do you know what firmware is installed on the NAS (RAIDar might tell you that)?
- JohncrispsApr 12, 2019Aspirant
Item 1 noted.
I've tried the following browsers on a win 7 and win 10 PCs, Edge, explorer, firefox, opera and an Avast browser, no luck.
Radar is not able to see any detail as described before.
Yhanks for the reply.
- StephenBApr 12, 2019Guru - Experienced User
You do need to enter http://nas-ip-address/admin to get into the web ui. http://nas-ip-address alone will look blank if there are no shares configured for http access. FireFox should work with newer firmware (4.1.16 for sure) - if the firmware is very old, then you could also try internet explorer 11 (or temporarily install an old browser version).
- JohncrispsApr 13, 2019Aspirant
Thank you for the info, I've now tried all the suggestions and also the following.
Set up the NAS on a different, separate non internet connected router,
Disbled all virus and other protection, tried access with win xp, win7 and win 10 machines but still no luck.
Conclusion is that the unit is kaput, so will now salvage the drives and bin the unit for a new more up to date model.
I thank you for your kind help and suggestions over the last few days.
All the best
John
