dsnpevl
Nov 24, 2014Virtuoso
No more web GUI after upgrade to 6.2.0
I have upgraded several times before without problems. But just now I upgraded from 6.1.9 to 6.2.0, but I can no longer go to the web admin page.
I can still access the file system on the NAS via Windows shares. The web interface of the Plex media server also works. So the connection is up and running. Just seems that port 80 is not responding.
When I log into the server via SSH, the welcome prompt does say:
Welcome to ReadyNASOS 6.2.0
- How long would a upgrade from 6.1.9 to 6.2.0 roughly take on RN516 (maybe I'm too impatient)?
- Any idea what can be wrong and how it can be solved?
- Can I risk rebooting?
- Any upgrade log I can watch to determine the status of the upgrade?
- dsnpevlVirtuosoIt's a symbolic link.
ls -al 090-jenkins.conf
lrwxrwxrwx 1 root root 23 Nov 24 22:59 090-jenkins.conf -> /apps/jenkins/http.conf
So I did this:cd /apps/jenkins
mv http.conf http.conf.oldsystemctl restart apache2
(no ouput on screen, indicating it started)
Now I can enter the admin web GUI again!
What is the impact of the changes we made?
Can I now uninstall Jenkins (I'm not using it anyway)? - dsnpevlVirtuoso
mdgm wrote: Interesting those two config files had different ports specified. That could be part of the problem.
I see.http://localhost:8443/jenkins
vshttp://localhost:8180/jenkins
But then one is for https and the other one is for http, so shouldn't there be different port numbers? - mdgm-ntgrNETGEAR Employee RetiredYou moved the Jenkins apache conf so it wasn't loaded.
Yes you should be able to uninstall it.
Ah. http vs https would explain that - dsnpevlVirtuosoThanks for your help!
Remaining issues:- Jenkins doesn't uninstall
- Cannot enable SSI and and virtual host any more (https://www.readynas.com/forum/viewtopic.php?f=36&t=73204#p408144), since the apache config has changed significantly.
Found a way to enable the SSI. Will create a post on that later for 6.2.0. - mdgm-ntgrNETGEAR Employee RetiredCan you remove it via SSH?
dpkg -l | grep jenkins
apt-get remove jenkins
apt-get purge jenkins
rm -rf /apps/jenkins - dsnpevlVirtuoso
ii jenkins 1.534.0 all Continuous integration system written in Java
The remove is complaining about missing dependencies.apt-get remove jenkins
Reading package lists... Done
Building dependency tree
Reading state information... Done
You might want to run 'apt-get -f install' to correct these:
The following packages have unmet dependencies:
cpp-4.7 : Depends: gcc-4.7-base (= 4.7.2-5) but it is not going to be installed
ffmpeg : Depends: libavcodec54 (>= 1.2.0) but it is not installable
Depends: libavformat54 (>= 1.2.0) but it is not installable
Depends: libavresample1 (>= 7:1.2.6) but it is not going to be installed
g++-4.7 : Depends: gcc-4.7-base (= 4.7.2-5) but it is not going to be installed
gcc-4.7 : Depends: gcc-4.7-base (= 4.7.2-5) but it is not going to be installed
lib32gcc1 : Depends: gcc-4.7-base (= 4.7.2-5) but it is not going to be installed
lib32stdc++6 : Depends: gcc-4.7-base (= 4.7.2-5) but it is not going to be installed
libavahi-client-dev : Depends: libavahi-client3 (= 0.6.31-2) but 0.6.31-4.netgear1 is to be installed
libavahi-common-dev : Depends: libavahi-common3 (= 0.6.31-2) but 0.6.31-4.netgear1 is to be installed
libc-dev-bin : Depends: libc6 (< 2.14)
libc6-dev : Depends: libc6 (= 2.13-38+deb7u6)
libc6-i386 : Depends: libc6 (= 2.13-38+deb7u6)
libdbus-1-dev : Depends: libdbus-1-3 (= 1.6.12-1) but 1.8.0-1 is to be installed
libgomp1 : Depends: gcc-4.7-base (= 4.7.2-5) but it is not going to be installed
libitm1 : Depends: gcc-4.7-base (= 4.7.2-5) but it is not going to be installed
libjpeg-turbo8-dev : Depends: libjpeg-turbo8 (= 1.2.1-netgear1) but 1.3.1-0.netgear1 is to be installed
libquadmath0 : Depends: gcc-4.7-base (= 4.7.2-5) but it is not going to be installed
libstdc++6-4.7-dev : Depends: gcc-4.7-base (= 4.7.2-5) but it is not going to be installed
perl : Depends: perl-base (= 5.14.2-21) but 5.14.2-21+deb7u2 is to be installed
tzdata-java : Depends: tzdata (= 2013c-0wheezy1) but 2014h-0wheezy1 is to be installed
zlib1g-dev : Depends: zlib1g (= 1:1.2.7.dfsg-13) but 1:1.2.8.dfsg-1 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution). - mdgm-ntgrNETGEAR Employee RetiredAh, I guess if you don't need to remove Jenkins there's not much harm leaving it there.
- dsnpevlVirtuoso
mdgm wrote: Ah, I guess if you don't need to remove Jenkins there's not much harm leaving it there.
I guess not, but I don't like leaving unstable apps on my NAS. The rm -rf got the directory cleaned out and also made the Jenkins logo move from Installed Apps back to Available Apps.rm -rf /apps/jenkins
In the mean time, a newer version of Jenkins became available (1.534.1) and I managed to install it and now the launch page shows up. So that's solved now too. - hedefalkAspirantThanks guys, I had the same problem with not accessing web ui after upgrade to 6.2.2 on my ReadyNas 104. I did:
rm /etc/apache2/sites-enabled
and got back online.
However, I need jenkins so I reverted that and just:
a2enmod proxy
service apache2 restart
which got me online with jenkins. Doing and upgrade just now of all my plugins so maybe the Jenkins thingy is fixed…
Cheers,
Viktor
instead which will make that command w
