Bails303
Oct 28, 2012Aspirant
No network link after disk 1 failure #19879784
Recently my Pioneer Pro's disk 1 failed and now, once fully booted, it does not recognize any network link from either of its ethernet ports, either when connected directly into the modem or even when...
Bails303
Dec 05, 2012Aspirant
siigna wrote: It was a case of OS corruption. I don't believe it was caused by the failed drive, more along the lines of your ReadyDLNA database filling up the OS partition. I sent you a case update with more details, there'll be a bit of reconfiguration to do once it comes back up. If you need any help my direct contact info's in the case update.
Thanks to you everything is now back to functioning absolutely perfectly. I'm very relieved to say the least.
Just such a relief to have my data back after nearly a couple of months - I was missing it to say the least! Now that I can access it all again, I'm backing it up like crazy so this situation never happens again.
Again, thank you sincerely for your constructive efforts.
