CristianoM
Sep 04, 2017Aspirant
No network link [RND4000]
I have a Readynas NV+ [RND4000v3] and i have a big problem. Inside there is all my data of my life and work. I've seen that similar problems, but was different. So please help me or at least guide m...
Sep 04, 2017Guru - Experienced User
It's unfortunate that you don't remember the RAID mode. You might have flex-raid with two RAID-1 volumes.
If so, wou can try installing R-linux for windows on a windows PC ( http://www.r-tt.com/free_linux_recovery/ ). Power down the NAS, and connect disk 1 to the windows PC (either using a USB adapter kit, or connecting the disk to the PC's internal SATA). Then see if R-linux can read it.
Another option is get a new ReadyNAS (perhaps an RN214 or RN414). Netgear support can help you mount the old NAS volume(s) so you can offload the data. More information is here: https://kb.netgear.com/29876/ReadyNAS-Migrating-disks-from-RAIDiator-4-1-or-RAIDiator-5-3-to-ReadyNAS-OS-6
Given the age of your disks, I suggest getting new ones with a new NAS. WDC Red or Seagate Ironwolf would be good choices
