rtosco
May 09, 2017Aspirant
No volume exists - Case #28413268
Disk array became suddenly unavailable and after a reboot system shows "No volume exists" message. dmesg.log shows following error: [Tue May 9 22:39:34 2017] BTRFS (device md127): bad tree block s...
- May 10, 2017
Thanks for your suggestions Stephen, however I managed to connect to my NAS via SSH and mount the array in read-only / recovery mode with command sequence:
mkdir /mnt/recovery
mount -t btrfs -o ro,recovery /dev/md127 /mnt/recovery
I'm copying all the data to various disks and then I'll try to repair the original filesystem with btrfs check --repair command.
If that does not work I'll reformat the array and copy back the data.
Hope this can help other users with similar troubles without having to pay money to fix someone else's software bugs...
Cheers from Italy,
Roberto
May 10, 2017Guru - Experienced User
Has support looked at it yet? It's probably best to wait for them at this point.
My guess is that you are facing data recovery. If so, it will cost, and results are not guaranteed. Netgear does provide that (support will give you the details, they are also here: https://kb.netgear.com/69/ReadyNAS-Data-Recovery-Diagnostics-Scope-of-Service ). Some users have reported success with a tool called ReclaiMe.
- rtoscoMay 10, 2017Aspirant
mkdir /mnt/recovery
Cheers from Italy,
Roberto
