rtosco's avatar
rtosco
No volume exists - Case #28413268
Disk array became suddenly unavailable and after a reboot system shows "No volume exists" message. dmesg.log shows following error: [Tue May  9 22:39:34 2017] BTRFS (device md127): bad tree block s...
  • rtosco's avatar
    rtosco
    May 10, 2017
    Thanks for your suggestions Stephen, however I managed to connect to my NAS via SSH and mount the array in read-only / recovery mode with command sequence:
    mkdir /mnt/recovery
    mount -t btrfs -o ro,recovery /dev/md127 /mnt/recovery
    I'm copying all the data to various disks and then I'll try to repair the original filesystem with btrfs check --repair command.
    If that does not work I'll reformat the array and copy back the data.
    Hope this can help other users with similar troubles without having to pay money to fix someone else's software bugs...
    Cheers from Italy,
    Roberto
ProSupport for Business
