NASCHARGE
Mar 25, 2018Aspirant
"No Volume Exists" After 6.9.3 Lockup
Hi,
Recently updated my NAS to 6.9.3 and found it locked up.
Unable to reboot it I had to drop power.
Not have the message "No Volume Exists"
Checked logs dmesg.log
[Sun Mar 25...
- Mar 27, 2018
Check volume with ubuntu and was able to see data still there (plugged all 6 drives into test rig)
put back into nas and ran
btrfs check --repair /dev/md127
rebooted once completed and all data is back again.
NASCHARGE
Then Check Disk
# btrfs check /dev/md127 parent transid verify failed on 1982502338560 wanted 12664 found 12435 parent transid verify failed on 1982502338560 wanted 12664 found 12435 parent transid verify failed on 1982502338560 wanted 12664 found 12435 Checking filesystem on /dev/md127 UUID: 6b2226c9-adf5-455b-bfff-a218cd7a0588 checking extents checking free space cache checking fs roots checking csums checking root refs checking quota groups Counts for qgroup id: 0/261 are different
Few similar errors after above.
Disks all say active and no errors from what I have worked out.
A little worried about not getting data back since cant mount (assuming I used the correct command)
