HappyFriday
Jul 14, 2017Aspirant
No volume exists
So I ordered some new 8TB drives, to put into my NAS due to space issues. Rebooted and I am getting an error http://imgur.com/a/ewVgq so I went ahead and powered back down and threw the old drive ba...
Jul 15, 2017Guru - Experienced User
You might try paid support (my.netgear.com) If you purchased new between 1 June 2014 and 31 May 2016 you have free lifetime chat support there.
jak0lantash
Jul 15, 2017Mentor
Maybe you want to upvote this "idea": https://community.netgear.com/t5/Idea-Exchange-for-ReadyNAS/Change-the-incredibly-confusing-error-message-quot-remove/idi-p/1271658
Support is probably you're best bet. If you want me to have a look, download the logs from the GUI, search for md127 in dmesg.log and paste an extract here.
- HappyFridayJul 15, 2017Aspirant
Here you go, tell me what you think. Thanks for any help.
[Fri Jul 14 19:17:03 2017] md: md127 stopped.
[Fri Jul 14 19:17:03 2017] md/raid:md127: device sda3 operational as raid disk 0
[Fri Jul 14 19:17:03 2017] md/raid:md127: device sdf3 operational as raid disk 5
[Fri Jul 14 19:17:03 2017] md/raid:md127: device sde3 operational as raid disk 3
[Fri Jul 14 19:17:03 2017] md/raid:md127: device sdd3 operational as raid disk 2
[Fri Jul 14 19:17:03 2017] md/raid:md127: allocated 6466kB
[Fri Jul 14 19:17:03 2017] md/raid:md127: not enough operational devices (2/6 failed)[Fri Jul 14 19:17:03 2017] md/raid:md127: failed to run raid set.
[Fri Jul 14 19:17:04 2017] md: md127 stopped.
[Fri Jul 14 19:17:04 2017] md/raid:md127: device sdd4 operational as raid disk 0
[Fri Jul 14 19:17:04 2017] md/raid:md127: device sdf4 operational as raid disk 3
[Fri Jul 14 19:17:04 2017] md/raid:md127: device sde4 operational as raid disk 1
[Fri Jul 14 19:17:04 2017] md/raid:md127: allocated 5410kB
[Fri Jul 14 19:17:04 2017] md/raid:md127: not enough operational devices (2/5 failed)[Fri Jul 14 19:17:04 2017] md/raid:md127: failed to run raid set.
- jak0lantashJul 16, 2017Mentor
HappyFriday wrote:[Fri Jul 14 19:17:03 2017] md/raid:md127: device sda3 operational as raid disk 0
[Fri Jul 14 19:17:03 2017] md/raid:md127: not enough operational devices (2/6 failed)[Fri Jul 14 19:17:04 2017] md/raid:md127: device sdd4 operational as raid disk 0
[Fri Jul 14 19:17:04 2017] md/raid:md127: not enough operational devices (2/5 failed)You have mixed capacities drives, 2TB and 3TB, which means you have (at least) two RAID arrays concatenated as a single BTRFS volume.
The NAS attempted to assemble the first RAID array (the base one) and failed as two disks are out of sync.
The NAS attempted to assemble the second RAID array (the secondary one) and failed as two disks are out of sync.
Two drives are out of both RAID arrays, so this is a Data Recovery situation. You should contact NETGEAR Support.
