Hplar_H
Mar 08, 2022Aspirant
no volumes after blackout on Readynas Duo V2
Ready NasDuo v2 with Radiator 5.3.13 with originally 2 HDD (X-Raid2) After a power outage in the neighbourhood the NAS lost access to the volumes. I have seen similar posts, but not a solution i...
- Mar 08, 2022
ReclaiMe is expensive (in part because it supports BTRFS). Another tool you can try is R-linux for Windows (which is free). https://www.r-studio.com/free-linux-recovery/
Have you tried simply booting the NAS with only disk 2 installed? If that fails, you could try again with only disk 1 installed (powering down before moving disks).
It is important to clarify the model - many v1 owners mistakenly think they have a v2. Does your NAS say "ReadyNAS Duo v2" on the front panel?
