knightfall3d
May 26, 2025Follower
No Volumes Exist Suddenly - ReadyNas 10400 - HELP!
I was in the middle of running a full backup of my readynas 10400 system yesterday and something has gone wrong. Now I cannot access the shares, and the system is showing the message that 'No Volume...
Sandshark
May 26, 2025Sensei
Making sure I have the timeline right. Did things happen in this order:
- Drive failed.
- You started backup.
- Volume went inactive during backup.
- You tried to see if a disk replacement would fix the issue.
Did you reboot at any time during that sequence?
If you left the failed drive alone while you did the backup, does the log indicate that the volume started to re-sync during that time?
There isn't one standard answer for this problem since there are multiple potential causes. StephenB​ will likely offer to look at your logs and better assess your issue by you downloading the log zip file, putting it in cloud storage, and PMing him the link to it.
