Cherzem
Aug 13, 2024Tutor
Not able to list directories from Onedrive
I have had working Cloud services (Google Drive and OneDrive) on my ReadyNAS Ultra 4 Plus running 6.10.10 for a very long time. This time I wanted to add a session for the OneDrive service. This f...
Cherzem
Aug 13, 2024Tutor
The closes post that contains relevant advice is https://community.netgear.com/t5/ReadyNAS-Cloud-Storage/Is-it-possible-to-sync-READYNAS-to-more-than-one-OneDrive/m-p/2162316#M13052
Since setting the cloud storage path fails the signing seems to fail as well. I have also cleared browser cookies before pressing "Leave".
Lockis
Sep 01, 2024Aspirant
Ì have the same problem, any solution yet?
- CherzemSep 01, 2024TutorNo, unfortunately
- strykerozSep 07, 2024Tutor
I'm having a parallel experience but with Wasabi. After it stopped syncing with the credentials error, I chose the option to leave, and have got to the same point as the OP where I get the Failed to list Wasabi directories message & I've been unable to progress further to reinstate Wasabi syncing. To get to this point it allowed me to choose the bucket, so the access keys are working fine.
If you guys get a solution on Onedrive I'm hoping it will be common to this Wasabi drama. If not, I'll switch to OD as I'm feeling a bit exposed without functional backup
- strykerozSep 26, 2024Tutor
Should we abandon all hope on a solution to this one you think?
