Cherzem
Aug 13, 2024Tutor
Not able to list directories from Onedrive
I have had working Cloud services (Google Drive and OneDrive) on my ReadyNAS Ultra 4 Plus running 6.10.10 for a very long time. This time I wanted to add a session for the OneDrive service. This f...
adameric
Feb 19, 2025Aspirant
Same problem here
- SandsharkFeb 19, 2025Sensei
I can show all Onedrive folders, I just can't select them for backup as you use to be able to do.
The solution I have found to that is to create a symbolic link to the folder you want to back up and put it in the OneDrive folder, or a folder you created therein. Take a look at this post: Using-OneDrive-for-NAS-backup-now-that-it-s-broken-on-the-Readynas . While I specifically talk about linking to shares on a NAS, the same process works for local folders.
You can also use any external backup/sync program with the target in the OneDrive folder.
- vandermerweApr 25, 2025Master
Oh no. This is terrible to hear. I've had these authorisation issues with the onedrive integration on Readynas before but it's extremely infrequent and although it involved having to recreate each session, it would always work. Now it is clearly broken ,presumably Microsoft trying to stop us from easily using the storage.
I am reliant on it as my cloud /offsite backup so I am trying to find an alternative method to recreate this without spending money. If anyone has a clean solution, please post it. I have looked at Sandshark's workaround, not really what I'm looking for.
Anyone know if this is affecting users of other NAS ?
- strykerozApr 25, 2025Tutor
vandermerwe wrote:Now it is clearly broken ,presumably Microsoft trying to stop us from easily using the storage.
I can't comment on other NAS being impacted, but granted it also fails on Wasabi, our NAS appears to be the common factor.
