ianw53
Jul 17, 2014Aspirant
Not Accepting Connections #23538265
I have a Readynas Ultra 6 which up until now has worked perfectly. However now it is no longer available. When running the windows diagnostics, it indicates that device is not accepting connections ...
mdgm-ntgr
Jul 19, 2014NETGEAR Employee Retired
It would be worth checking your disks. As the support agent pointed out one of them has reallocated sectors.
There is a disk test boot menu option, but if you can power down, remove your disks (label order) and check them that would be better.
