Bennp2000
Dec 16, 2013Aspirant
Not appearing on Win7 Network
Hi all, Had my ReadyNas Duo for some time now and today my router randomly decided to return to factory settings. Stupidly I didn't have a backup but within 30 mins or so I had my home network up and...
smtoff_1
Jul 08, 2014Aspirant
Have the same problem on a couple of Windows PCs in a network. Simple workgroup and have put the network mapping in explorer but have done it for both the \\192.... and the \\NASNAME\ variants just in case. Problem not addressed here is that if you want to work with say Excel file on NAS server frequently, the recent files gets mucked up when it can't see the \\NASNAME\.
Not a critical problem here but makes you wary of integrating NAS. For example I use Memeo to save files from the windows PCs and it frequently gets stalled "looking for path".
