PatrikL
Oct 12, 2011Aspirant
Not getting cron to work
I've tried to get a script (importing torrent files from rss) executed once an hour by simply placing it in cron.hourly but nothing whatsoever happens. The script executes well manually when I'm logge...
PatrikL
Oct 13, 2011Aspirant
sphardy wrote: Does the script run properly if you execute it as /usr/bin/python <script> ??
If so, might be easier to just create your own cron schedule (crontab -e) and explicitly define the command to be run
Yes it does so I'll try that. thanks
