BrucKlin
Mar 24, 2023Aspirant
Not sure what do about my old ReadyNAS NV+ v2 to make use of it?
Hi Experienced Readynas folks, I have an old 4-bay ReadyNAS NV+ v2 that I brought out of retirement after not using for a long time. It booted up and seems to work fine for over a week now, with...
Mar 24, 2023Guru - Experienced User
BrucKlin wrote:
What I would like to do - is to pull all the drives out and rebuild from scratch, replace them all at once with 6TB drives and then rebuild / reformat / reconfigure ( whatever the correct terminology is ) the whole system.
Yes, you can do that, and it will be faster than replacing them one at a time.
BrucKlin wrote:
Q1 - Is there a manual or list of steps here online that I can follow to rebuild this NAS from scratch as if I had just bought it diskless?
One thing to triple-check is whether you have the original NV+ or an NV+ v2
The original NV+ (called v1 here):
- says ReadyNAS NV+ on the front panel
- runs 4.1.x firmware
- often has other labels that say v2 or v3 - these are confusing, and should be ignored.
The NV+ v2
- says ReadyNAS NV+ v2 on the front panel
- runs 5.x firmware
Once we confirm the model, we can provide the manual links.
BrucKlin wrote:
Q2 - Can anyone estimate about how much space I will get if I can get 4 x 6TB drives in XRaid-2 configuration? Is it close to 18TB in one big volume? That would be awesome.
This depends on the model question above. The original NV+ only supports disks <= 2 TB. Larger disks will install, and appear to work, but the volume size will be very wrong.
But if you do have an NV+ v2 running 5.3.x firmware, then you will get an 18 TB RAID-5 volume.
Though you aren't asking about disk models, I'll comment on that anyway. WD Red Plus drives and Seagate Ironwolf drives are both good options. Avoid desktop-class drives and ordinary WD Reds - both use SMR technology, and don't work very well in ReadyNAS. Enterprise class drives are fine, but IMO are overkill for your model.
BrucKlin
Thanks StephenB:
ReadyNAS_NV+_V2
Radiator_5.3.13
