GlueGuy
Jan 25, 2014Aspirant
NV+ backup/expand/restore
After living happily with our NV+ for several years, we are now ready to expand the storage. We currently have a 1TB config (4 by 250MB XRAID), and plan to replace the HDs to a total of 4TB (4 by 1TB...
vandermerwe
Jan 26, 2014Master
Raidar is just a readynas discovery utility and provides some key information, when you click on setup in raidar you are then linked to the readynas admin system which is called Frontview. This is what you would have used for your firmware update.
Frontview has a backup facility to pull or push data from the readynas. You can program the backup button to run all or some of the backup jobs you have set up in Frontview.
