GlueGuy
Jan 25, 2014Aspirant
NV+ backup/expand/restore
After living happily with our NV+ for several years, we are now ready to expand the storage. We currently have a 1TB config (4 by 250MB XRAID), and plan to replace the HDs to a total of 4TB (4 by 1TB...
mdgm-ntgr
Jan 29, 2014NETGEAR Employee Retired
If you last did a factory reset on RAIDiator 3.x (sounds likely from what you've posted) it is probably doing an offline expansion. Expansion can take a long time. Is it still stuck at the same percentage?
