GlueGuy
Jan 25, 2014Aspirant
NV+ backup/expand/restore
After living happily with our NV+ for several years, we are now ready to expand the storage. We currently have a 1TB config (4 by 250MB XRAID), and plan to replace the HDs to a total of 4TB (4 by 1TB...
GlueGuy
Jan 29, 2014Aspirant
mdgm wrote: If you last did a factory reset on RAIDiator 3.x (sounds likely from what you've posted) it is probably doing an offline expansion. Expansion can take a long time. Is it still stuck at the same percentage?
Our RAIDar is 3.01c1-p1. I'm not sure we've ever updated it.
It stayed stuck at 1.3% from ~~ 8:30 AM until almost 5PM, then suddenly jumped to 17.2% (I was not there when it moved).
Then around 6PM there was another jump to 61.7%. It's now about 6:20PM, and it's still stuck at 61.7%.
Kind of stunning that it's been almost 10 hours with virtually no signs of life (other than the repetitive blinking lights on the front panel).
