Mike_NAS
Mar 29, 2015Aspirant
NV+ boot(?) issues - disks are clean
I started having a problem where my NV+ would freeze. It was kind of weird in that all of the LEDs would go out (even the power LED), but the LCD would stay lit with just general volume information o...
Mar 30, 2015Guru - Experienced User
You could try booting it up once again and deleting all the logs (system and backup). Don't download them. If that helps, then enable ssh, and then you can check the fullness of the OS partition.
