ChrisMc73
Aug 04, 2011Aspirant
NV+ Boot Issues - Weird LED Pattern Case #16319419
I checked out the LED patterns here: http://www.readynas.com/download/docume ... AS-LED.pdf There wasn't a pattern that matched mine, so I'm hoping someone can lead me in the right direction for this...
mdgm-ntgr
Aug 04, 2011NETGEAR Employee Retired
Btw you can get UPS units which allow you to connect a UPS to your NAS. In addition to connecting the ReadyNAS's power cable to the UPS you can connect a USB cable to the UPS. Consult the HCL.
Does your UPS provide surge protection? Do you have an ethernet surge protector on the NAS end of the ethernet cable plugged into the NAS?
Do the network lights light up at all when you turn the NAS on? Have you tried a different ethernet cable? Have you checked to make sure your router/switch is working properly?
