haupino
Jul 09, 2012Aspirant
NV+ failed to boot, volume not found after OS reinstall.
Hi. I've got an NV+ that stopped booting, stuck in "Booting..." with disk 4 and power led pulsating. TFTP recovery did not help, but holding down the reset button for 5 secs to reinstall OS had...
ReadySECURE
Jul 09, 2012Apprentice
I would have refrained from doing and OS reinstall until you knew exactly the cause of the issue.
An OS reinstall clears the logs, so we won't have any way to troubleshoot the problem to find out the initial cause.
What was the purpose of doing a TFTP recovery? Did you TFTP recover ReadyNAS 3.x firmware or did you TFTP 4.x? If you were on 4.x, and downgraded to 3.x, it is possible you ruined your volume and would need to start over.
The cause is probably a bad disk that was preventing it from booting to begin with; you indicated disk 4 was blinking... I would have started by turning off the device, pulling disk 4, and then rebooting the device to see if it starts.
I would highly recommend calling into support to see if there is anything they'll be able to do to assist you with your device.
