h4lt3r
Sep 06, 2011Aspirant
NV+ hangs while downloading torrents
Hi! I have NV+ with three 1.5Tb Seagate ST31500341AS drives installed in x-raid. I started using default torrent client, but it was quite buggy and was randomly loosing downloads, so i installed T...
oudijzergek
Oct 05, 2011Aspirant
Try re-installing the firmware the hard way. Switch it off, insert straightened paperclip and push reset on the rear, keep it pressed, switch it on. Keep your eye on the drive leds. As soon as they blink once let go of the reset switch. It will then start the re-install procedure.
