Kris_TH
Oct 03, 2011Aspirant
NV+ RND4000
Brand new NV+ RND4000 with 4x 2TB WD Disks. Did a factory reset after installing the disks. At about 50% of creating the volume the display, all leds (including the blue power led) and the network...
Oct 05, 2011Guru - Experienced User
The thought is that the failure may be disk-drive related - and that you might get different results if you remove all the disk drives.
Kris_TH wrote: As I already mentioned twice, there's no network activity so there's really no point in even starting RAIDar, now is there...
If you get the same results as before, then the problem is definitely in the chassis. But if you see the "no disk detected", then the next step would be to run diags on the drives.
