Kris_TH
Oct 03, 2011Aspirant
NV+ RND4000
Brand new NV+ RND4000 with 4x 2TB WD Disks. Did a factory reset after installing the disks. At about 50% of creating the volume the display, all leds (including the blue power led) and the network...
PapaBear1
Oct 05, 2011Apprentice
If it is the chassis, return the unit to the vendor for replacement of a dead unit. If you RMA the unit with Netgear, you will receive a refurbished unit. With a unit failing on it's first boot, you deserve a new unit.
