edk1
Feb 28, 2013Aspirant
NV+ serious performance problems, high iowait
Hi, I am running two almost identical ReadyNAS NV+ units in a network. One has terrible performance problems, the other is fine. The specs are as follows Good unit: firmware v4.1.7, 1GB RAM, 4 x...
Feb 28, 2013Guru - Experienced User
Do you have a scratch disk you could try in the bad unit? (powering down/removing the 3 disks in there).
Alternatively, power down both units, and swap the disks (preserving slot order!)
