blodclot
Jan 06, 2012Aspirant
NV+ stuck in Quota Check
Hi all, New to this forum and of course with a problem. I have a NV+ with 3 discs, 2 Seagate ST31000322CS (came installed in the NAS) and 1 ST32000641AS (which I added 2 months ago). The problems s...
Nam1
Jan 07, 2012Aspirant
Hi,
It looks like the HD you installed has 4K sector size, which is not compatible with the original HD (512 bytes sector) delivered with the NV+. May be this is creating a sync problem. The only way to use 4K sector disks is to backup the data you have and replace all the disks with new 4K sectors ones. In fact you have to create a brand new raid system. Make sure that you have the latest firmware.
Nam
Nam
