blodclot
Jan 06, 2012Aspirant
NV+ stuck in Quota Check
Hi all, New to this forum and of course with a problem. I have a NV+ with 3 discs, 2 Seagate ST31000322CS (came installed in the NAS) and 1 ST32000641AS (which I added 2 months ago). The problems s...
blodclot
Jan 11, 2012Aspirant
Thank you. I will try this. But on the compatibility list it states that this HD can be used. And Netgear also states that you can mix types of HD as long as they are on the compatibility list. So I thought this would not be a problem.
