platonium
Oct 26, 2014Aspirant
NV+ v1 full backup - how long?
Hi, I have an NV+ v1 running a full backup via FrontView to an attached USB external HD (plugged into rear top port). External drive formatted as NTFS. FrontView found the USB HDD and has been runni...
Solomon22
Aug 09, 2015Aspirant
and what USB speed for backup to FAT32 USB drive??? I use ReadyNAS DUO v1
Aug 09, 2015Guru - Experienced User
FAT32 is a bad idea if you have large files, as it can't hold anything > 2 GB.
For USB speeds with the Duo v1 see this post which has some rough estimates:
chirpa wrote: The speeds are something close to this:
NTFS = 2.5MB/s
FAT32 = 5MB/s
EXT3 = 10MB/s
EXT2 = 14MB/s
The fastest way to back up a v1 is over a gigabit network. Even fast ethernet is much faster than NFS/FAT32 speeds.
