kine
Jun 14, 2013Aspirant
NV+ (v1) repeatedly shuts down for no reason
About a month ago, one of my four drives died. I pulled it out (the unit wouldn't even boot with it in) and 3 or 4 days later i replaced it. The new one is a different model from the three old ones, b...
kine
Jun 15, 2013Aspirant
Thank you for the replies. df output looks like this:
I will try removing it from the UPS.
It sounds pretty wise to upgrade the drives too, but i don't think i even have a computer with a CD-ROM... :|
legnica:root # df -i
Filesystem Inodes IUsed IFree IUse% Mounted on
/dev/hdc1 128000 19709 108291 16% /
tmpfs 7070 1 7069 1% /USB
/dev/c/c 182812672 968819 181843853 1% /c
legnica:root # df -h
Filesystem Size Used Avail Use% Mounted on
/dev/hdc1 1.9G 741M 1.2G 38% /
tmpfs 16k 0 16k 0% /USB
/dev/c/c 5.4T 2.0T 3.4T 36% /c
